I have enabled the above feature using the command “lnms config:set debug.run_trace true”.
However I cannot find anywhere within the host or the alert screens in the web UI where this trace data shows.
Can you please point me in the right direction to find this?
I’ve tested this with PING only devices to ensure the outage relates to ICMP timeouts.
I’m on the latest production update with a successful daily.sh run so am sure this isn’t because the version I’m running doesn’t have the feature implemented.
You should see another tab on the device screen - but only when the latest poll was unsuccessful due to icmp. If that’s the case, is traceroute installed and in /usr/bin/traceroute?
Thanks for the update on this, just to confirm that it’s now showing a traceroute in the frontend.
Is there an opportunity to save the previous x number of traceroute outputs for comparison which would be excellent intel when diagnosing faults and network change?
For anyone else reading the thread, the traceroute shows in the ‘Overview’ screen under ‘Device Info’ and ‘Device Groups’.
