Hi guys, i’m just installed the Librenms system and creating alert for alert rules but i can’t find the Transport field in alert rules configuration to choose. Can you guys please help to check? Really appriciate for any helps. Below is my ./validate info. Thanks.
| LibreNMS | 26.8.0-dev.43+5475230a8 (2026-07-29T21:27:38+07:00) |
| DB Schema | 2026_07_29_000000_make_mpls_vpn_vrf_description_nullable_in_vrfs_table (395) |
| PHP | 8.3.6 |
| Python | 3.12.3 |
| Database | MariaDB 10.11.14-MariaDB-0ubuntu0.24.04.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.4.pre2 |
[OK] Composer Version: 2.10.2
[FAIL] Some poller nodes have not checked in recently
Inactive Nodes:
CMSRVNMS01
[FAIL] Scheduler is not running
sudo cp /opt/librenms/dist/librenms-scheduler.service /opt/librenms/dist/librenms-scheduler.timer /etc/systemd/system/
sudo systemctl enable librenms-scheduler.timer
sudo systemctl start librenms-scheduler.timer
