I followed this guide and instead of editing /etc/apache2/sites-available/000-default.conf, I edited /etc/apache2/sites-available/librenms.conf
https actually does work, but now that it’s set up, when I go to the LibreNMS web front-end, I am now presented with the Apache2 Ubuntu Default Page instead of seeing the LibreNMS login page.
I went through the guide a few times to make sure I didn’t miss anything and I can’t figure out what I’ve done wrong. I made sure to specify the FQDN of the server everywhere I could (in the cert and in all the config files).
EDIT: I think the problem is that I ran “sudo a2ensite default-ssl” but it should probably be the file that relates to librenms… however, I don’t know exactly if this is correct. “sudo a2ensite librenms.conf” just tells me that it’s already been enabled.
And I made these changes to default-ssl.conf: DocumentRoot /opt/librenms/html (was previously /var/www/html)
Why would I need to enable PHP for HTTPS? The website works fine as is. I’m just having trouble with getting things to run through HTTPS. I think it’s due in part to the fact that I followed a HTTPS guide that was going by the default site, and LibreNMS uses it’s own set of files. So I need to properly translate the walk-through to apply to the LibreNMS files… that is where I am running into issues…
