I am trying to troubleshoot an error with Librenms.
When trying to access the WebUi, I get the classical " Whoops, looks like something went wrong. Check your librenms.log."
My platform:
Description: Ubuntu 18.04.5 LTS
My output on ./validate.php shows:
LibreNMS | 21.6.0
DB Schema | 2021_02_09_122930_migrate_to_utf8mb4 (204)
PHP | 7.4.20
Python | 3.6.9
MySQL | 10.5.10-MariaDB-1:10.5.10+maria~bionic
RRDTool | 1.7.0
SNMP | NET-SNMP 5.7.3
====================================[OK] Composer Version: 2.1.3 [OK] Dependencies up-to-date. [OK] Database connection successful [FAIL] Your database is out of date! [FIX]: ./lnms migrate [WARN] Your local git contains modified files, this could prevent automatic updates. [FIX]: You can fix this with ./scripts/github-remove Modified Files: bootstrap/cache/.gitignore logs/.gitignore rrd/.gitignore storage/app/.gitignore storage/app/public/.gitignore storage/debugbar/.gitignore storage/framework/cache/.gitignore storage/framework/cache/data/.gitignore storage/framework/sessions/.gitignore storage/framework/testing/.gitignore storage/framework/views/.gitignore storage/logs/.gitignore
I am currently trying to update Python from 3.6.9 to 3.9.5 and all of the installation progress seems to be fine and dandy, but when i run ./validate it shows 3.6.9 still. And yes, I have rebootet after installing. Any suggestions on how to fix this?
