Hi everyone,
We have a small issue. I’ve added/enabled the bind application. Tried it with the agent and the info isn’t being graphed.
If I run the /usr/lib/check_mk_agent/local/bind command I do get output/results. But nothing in LibreNMS. Anyone any tips?
https://pastebin.com/rfNtmpFz
This is the oudput of validate.php:
| Component |
Version |
| LibreNMS |
1.36-70-gc14efbf90 |
| DB Schema |
235 |
| PHP |
7.0.27-0+deb9u1 |
| MySQL |
10.1.26-MariaDB-0+deb9u1 |
| RRDTool |
1.6.0 |
| SNMP |
NET-SNMP 5.7.3 |
We are running Debian 9.
Kind regards,
Hans
Did you enabled the unix agent for that device?
At the moment it is enabled.
I can think of a couple of problems;
- Firewall (did you opened port 6556?)
- Is the “only_from” variable set in xinetd/check_mk file? And if so, is that the host your trying to connect from (your librenms host)? Also, is the disable variable set to no?
- Can you telnet from your librenms host to the server you want to check (telnet 6556) ?
- Is the bind file put in the correct folder (/usr/lib/check_mk_agent) and did you use the correct bind file (there is one for SMTP and one for xinetd/check_mk)?
- What is the output if you run the file manually (as root)?
