I just finished adding around 400 devices by hand to Libre, and I finally got a working network map! I have tried my best to use iperf around the network to force the map to change color where to see if the dynamic colors actually are working. Is there a way to edit the legend?
0 -> 5% = green
6 -> 10% = light blue
11 -> 15% blue
16 -> 20% dark blue
I’ve just discovered that, in the custom map editor, you can first toggle legend to be visible, then you can select a part of the legend and “edit node”.
In this way you can customize colors and legend steps as you wish.
