Two Factor QR Code not showing, instead redirected to default/home URL
First of all, this is my first post here at LibreNMS forum.
I have been trying out LibreNMS for both work and home projects and today I went on to try out Two Factor Authentication feature but whenever I clicked on Generate Two Factor Secret Key under My Settings, it always redirects me to the home page with nothing happening. I have tried it with an admin user as well as a read only user. On Chrome, Vivaldi and Firefox with Incognito mode also.
The Two Factor Settings has been enabled on the Global Settings as well.
Has anyone experience this problem as well? What did you do to resolve this?
Thanks for reading my issues. Have great day.
VALIDATE OUTPUT:
LibreNMS 22.6.0-4-gdc3ddbaff
DB Schema 2022_05_30_084932_update-app-status-length (242)
PHP 7.4.3
Python 3.8.10
MySQL 10.3.34-MariaDB-0ubuntu0.20.04.1
SNMP 5.8
[OK] Composer Version: 2.3.7
[OK]
[OK] MySQl and PHP time match
Anyone, please?
Yes, he has this bug. I didn’t have time to debug or report to the community.
If you type ./lnms config:set twofactor true in the CLI it will work.
Thank you so much! It works! Looks like the Web UI has a bug.
