Two ISP BGP Alert
Hi!
I have on cisco 2811 two ISP with whom I peer on BGP. How to set an alert, so I understand some of the operators fell?
Did you add rule from collection and add the bgp alert? That might do what you want.
Hello, murrant!
Yes, i did.
But I receive a General notification about the fall of BGP, and I need to know which of the providers fell.
I try add custom template, but this doesn’t work:
“State: BGP{if %bgpPeers.bgpPeerRemoteAs == 20485}TTK{/if}{if %bgpPeers.bgpPeerRemoteAs == 65535||8359||13055}MTS{/if}{if %bgpPeers.bgpPeerState != established}DOWN{/if}{if %bgpPeers.bgpPeerState == established }UP{/if}
Device: %sysName
IP : %hostname
Date: %timestamp”
Try this:
%title\r\n
Severity: %severity\r\n
{if %state == 0}Time elapsed: %elapsed\r\n{/if}
Timestamp: %timestamp\r\n
Unique-ID: %uid\r\n
Rule: {if %name}%name{else}%rule{/if}\r\n
{if %faults}Faults:\r\n
{foreach %faults}
#%key: %value.string\r\n
Peer: %value.astext\r\n
Peer IP: %value.bgpPeerIdentifier\r\n
Peer AS: %value.bgpPeerRemoteAs\r\n
Peer EstTime: %value.bgpPeerFsmEstablishedTime\r\n
Peer State: %value.bgpPeerState\r\n
{/foreach}
{/if}
Thx, Rosiak!
How i can disable recovery message to my alert rules?
its not possible to disable recovery at this time.
