Hi, I have worked though steps to install librenms on Rocky 8 using rocky or centos instructions and I get the same results:
- This file does not exist - /opt/librenms/librenms.nonroot.cron
- When I access the server the GUI is messed up. I can validate the database but I can’t do much else.
bash-4.4$ ./validate.php
| LibreNMS | 24.1.0-67-gd6ce29c05 (2024-02-06T07:42:36-08:00) |
| DB Schema | Not Connected (0) |
| PHP | 8.1.27 |
| Python | 3.6.8 |
| Database | Not Connected |
| RRDTool | 1.7.0 |
| SNMP | 5.8 |
[OK] Composer Version: 2.6.6
