Hi there,
Could you please help me with Unifi switches.
How i can find OID’s or mib’s that was used when unifi switches were added to LibreNMS ?
Hi there,
Hi @menvol3
Please explain us your issue so we can see what you need ![]()
Hi, @PipoCanaja
I have UBNT equipment (2 unifi swithes) and now i need to find OID to poll some data what i wanted to know with snmpwalk
I see that ubnt devices successfully added to LibreNMS, and i think that you already have those OID’s.
Now i wanted to know if there any possibility to find it inside your project ?
If we already have them, then you will see it right away when you import the devices in LibreNMS. So if you don’t see your values/sensors, then we don’t have them yet and you need to add them.
In order to see the discovery process, you can run, from librenms user in CLI :
./discovery.php -h <deviceID> -v -d
Depending on the OS we match this device, the description can either be done in YAML file ( include/definitition/<os>.yaml and include/definitition/discovery/<os>.yaml) or in PHP.
The documentation will let you discover all this :
https://docs.librenms.org/Developing/Support-New-OS/
Bye
Ok, my device already added and sensors showing data.
But how they read those device, how i can acces to the mib’s or OID’s that were used when device was discovered ?
Exactly as described in my previous post : run discovery.php with debug and verbose options.
Or read the YAML files (definition/discovery/.yaml) that details the OIDs that are discovered. Some are also discovered via PHP (search all files with name .inc.php).
