trying to load a Toughswitch 8 POE Pro into libre(Now called the Edgeswitch XP 8, rebranding…) and it is showing up as an airfiber device running AirOS.
I’m seeing the same behavior here. Funny thing is it worked correctly the first day or so after I added it. Mine also only shows two eth ports instead of eight like it should.
The ToughSwitch line runs airOS, I believe. Also, the interfaces you’re seeing are the CPU interfaces and not the switch interfaces. Most of this is due to UBNT not updating the MIB for the TS line in a long long time.
