I took a leap and tried to update my Ubuntu host from 17.10 to 18.04 and that actually went well. I ran into trouble updating PHP from 7.1 to 7.2. It all installed okay and I got all of the modules, but something odd is happening where after the update, I validate okay, but when I browse there, it states the following:
Text version:
Missing PHP extensions. Please install and enable them on your LibreNMS server.
mbstring
curl
Here’s the validate.php output:
LibreNMS | 1.47-97-g1bb782b6d
DB Schema | 2019_01_16_195644_add_vrf_id_and_bgpLocalAs (131)
PHP | 7.2.14-1+ubuntu18.04.1+deb.sury.org+1
MySQL | 10.1.34-MariaDB-0ubuntu0.18.04.1
RRDTool | 1.7.0
SNMP | NET-SNMP 5.7.3
[OK] Composer Version: 1.8.0
I’ve tried to purge old versions, purge the 7.2 versions of curl and mbstring and reinstall them, and nothing has seemed to work after reboots and apache service restarts, etc.
running the following shows the modules:
php --ini
Ouput:
/etc/php/7.2/cli/conf.d/20-curl.ini,
/etc/php/7.2/cli/conf.d/20-mbstring.ini,
Needless to say, I’m a little bit at a loss and would love some help here.
Thanks!
(Edits for formatting)
