Hi there,
I did cek to make test the transport, it said “Test to telegram ok”
and this is my default alert template:
and here is my validate.php result
!Component | Version
!LibreNMS | 1.69-29-gf4ea49e38
!DB Schema | 2020_11_02_164331_add_powerstate_enum_to_vminfo (190)
!PHP | 7.4.11
!Python | 3.6.9
!MySQL | 10.5.7-MariaDB-1:10.5.7+maria~focal-log
!RRDTool | 1.7.0
!SNMP | NET-SNMP 5.7.3
!OpenSSL |
![OK] Composer Version: 2.0.6
![OK] Dependencies up-to-date.
![OK] Database connection successful
![OK] Database schema correct
![WARN] Your local git contains modified files, this could prevent automatic updates.
![FIX]:
!You can fix this with ./scripts/github-remove
!Modified Files:
!syslog.php
!*note: I modified syslog.php
