Unable to access Web Interface
I have updated my Centos 7.5.1804 with latest updates.
I have updated my install by manually running ./daily.sh as it was not running via cron and have no errors when running ./daily.sh and ./validate.php with the exception of polling and discovery haven’t run in like 5 minutes.
Mariadb, Httpd, and snmpd are running without errors.
However, I cannot access the webgui…not even to login.
Please help!
post the output put of ./validate.php please
Here is the output while running at root user -
[[email protected] librenms]# ./validate.php
LibreNMS 1.40-40-g0ba76e6
DB Schema 253
PHP 7.2.6
MySQL 5.5.56-MariaDB
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
[OK] Composer Version: 1.6.5
[FIX] Check your poll log and see: http://docs.librenms.org/Support/Performance/
Devices:
172.16.130.100
[FAIL] Some devices have not completed their polling run in 5 minutes, this will create gaps in data.
Devices:
172.16.130.100
[WARN] Your install is over 24 hours out of date, last update: Sat, 30 Jun 2018 11:19:49 +0000
Here is the output while su librenms user -
[[email protected] librenms]# su librenms
bash-4.2$ ./validate.php
DB Schema 253
PHP 7.2.6
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
Devices:
172.16.130.100
Devices:
172.16.130.100
Working now. Just decided on its own time to start working.
Okay, you should look at what the validation was telling you may still have some issues
