Hi All,
Would like to ask your expert advise.
Could not ping error when adding a device in GUI.
Using OVA Built with VirtualBox.
Manage to clear all error when running:
./daily.sh
./validate.php
able to ping successfully but receives an error when adding a device.
Please check attached screenshot.
(not sure if I have to install selinux)
Please help.
Chas
11 June 2019 11:41
#2
You are getting duplicate ping packets, I would try to solve that first.
Try updating Virtualbox
fping does not handle duplicate packets right. I couldn’t replicate it, so I couldn’t fix it. Maybe if you could packet capture it, I could replay it?
After fixing the duplicate packet error by ssuing command “sysctl net.ipv4.ip_forward=0” on the host machine. (not guest)
I am now able to add device properly.
Thank you for your help Chas and murrant.
