I am at the first page of the web installation and not able to proceed.
The pre-install checks state the following:
Session directory writable = no comment: /var/lib/php/session is not writable.
The directory exists but is owned by root. Not sure if that is expected behavior.
As an aside. I have oxidized running on the same server and was setup with oxidized in mind only until I came across LibreNMS so running all commands under the “oxidized” as I ran through that instruction set to get that running.
uname:
Linux librenms.example.com 3.10.0-693.21.1.el7.x86_64 #1 SMP Wed Mar 7 19:03:37 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
Thanks and let me know if there’s more information required.
