during night our virtual machine with librenms crashed due to no free space on hdd.
We fixed it and now everything look like its working except rules.
When i try to create rule, i dont see those fancy filter options:
when i click on save rule, nothing happens.
when i click on edit on some existing rule, i get exactly same window (with predefined “aa” in rule name)
when i try to delete rules, i get ajax post failed; unable to delete alert rule
Everything else look like its working, i can add/remove devices, rrds and graphs are updated continually.
in librenms.log i got only these messages:
/opt/librenms/poller.php 14 2020-04-03 14:55:35 - 1 devices polled in 32.26 secs
validate looks ok:
→ ./validate.php
| LibreNMS | 1.62-16-g7d2a1ae79 |
| DB Schema | 2020_03_25_165300_add_column_to_ports (161) |
| PHP | 7.2.28-4+0~20200224.38+debian9~1.gbp1ca010 |
| MySQL | 10.1.44-MariaDB-0+deb9u1 |
| RRDTool | 1.6.0 |
| SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.10.1
Modified Files:
bootstrap/cache/.gitignore
logs/.gitignore
rrd/.gitignore
storage/app/.gitignore
storage/app/public/.gitignore
storage/debugbar/.gitignore
storage/logs/.gitignore
Files:
/opt/librenms/.git/index
thanks for any help!
