Unable to edit device port settings
I would like to limit which ports I’m polling for each device. However, the Port Settings page doesn’t seem to be working on any devices:
I tried testing Device page dropdown hero button, Performance -> Latency by murrant · Pull Request #11328 · librenms/librenms · GitHub, but this did not resolve the issue.
$ ./validate.php
LibreNMS  | 1.62-5-gbbe88c71b
DB Schema | 2020_03_25_165300_add_column_to_ports (161)
PHP       | 7.2.24-0ubuntu0.18.04.3
MySQL     | 10.1.44-MariaDB-0ubuntu0.18.04.1
RRDTool   | 1.7.0
SNMP      | NET-SNMP 5.7.3
[OK]    Composer Version: 1.10.1
You have to click the button twice, hence, the message.
Yes, I did try this. That didn’t work here or on other tabs with this message.
Perhaps you have another issue. Check the web browser console log for errors.
I checked the same two places you recommended for another issue and see the same errors on the port edit page:
this is the same issue as the other one you opened, closing this.
