Hello! I would like to activate 2FA to an admin account
I am encountering the same problem as described in that thread
General auth settings are ok
And when I go to Generate Two factor Secret key ( both TOTP and HTOPT) I’m redirected to base url, this is the http response:
POST payload:
_token: qF****************************zLDlIJ17
twofactortype: counter
Nothing strange in librenms.log, browserlog says flasher not loaded but I don’t think it’s related.
I have installed the debug toolbar for laravel, but I can’t find how to debug it, if someone can help me and we can find out where the problem is.
I can confirm de same behaviour at other installation that I manage :
| Version | 22.11.0 - Sat Nov 26 2022 17:55:27 GMT+0100 |
| Database Schema | 2022_09_03_091314_update_ports_adsl_table_with_defaults (248) |
Thanks you!
LibreNMS | 24.1.0-42-g0b8413ed9 (2024-01-19T16:14:29+01:00)
DB Schema | 2023_12_12_171400_alert_rule_note (277)
PHP | 8.1.2-1ubuntu2.14
Python | 3.10.12
Database | MariaDB 10.6.12-MariaDB-0ubuntu0.22.04.1
RRDTool | 1.7.2
SNMP | 5.9.1
[OK] Composer Version: 2.6.6
