I followed the documentation for fast ping checking (1 minute) and so far it appears to not be working for me. Devices are only discovered down after the ICMP check with the polling cycle.
Here are my config.php changes:
$config['fping'] = "/usr/sbin/fping";
$config['ping_rrd_step'] = 60;
$config['fping_options']['retries'] = 2;
$config['fping_options']['timeout'] = 500;
$config['fping_options']['interval'] = 500;
I ran the “./scripts/rrdstep.php -h all” command.
Here is my /etc/cron.d/libernms file:
* * * * * librenms /opt/librenms/ping.php >> /dev/null 2>&1
* * * * * librenms /opt/librenms/alerts.php >> /dev/null 2>&1
*/5 * * * * librenms /opt/librenms/html/plugins/Weathermap/map-poller.php >> /dev/null 2>&1
15 0 * * * librenms /opt/librenms/daily.sh >> /dev/null 2>&1
I’m not sure where I am going wrong with the instructions or if there is maybe something else wrong with my install. I also have this issue with the validate script.
LibreNMS | 1.51-70-g83522c6
DB Schema | 2019_02_10_220000_add_dates_to_fdb (132)
PHP | 7.2.17
MySQL | 5.5.60-MariaDB
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
[OK] Composer Version: 1.8.5
Files:
/opt/librenms/bootstrap/cache/packages.php
This permission issues pop up for me once in a while. I run the fixes then run the validate script again and it comes back with everything “OK”. If I run the script again in a few days, it’ll tell me that I have those same permission issues again.
