Hello all, I am pretty new to Libre and I’m trying to get slack notifications working on an install I’ve inherited. Alert rules are setup and being matched by devices with the condition (in this case failed PSU).
When I test the transport for the alert I see the slack notification - and I even see the notification in slack when I run test-alert.php
against the rule/device…
My initial google searches lead me to a possible issue w/ mismatch timezone configuration of php.ini
in FPM and CLI but that appears to be correct, here is the output of my validate - scratching my head…
$ ./validate.php
LibreNMS | 22.8.0-1-g465fa3986
DB Schema | 2022_07_03_1947_add_app_data (244)
PHP | 7.4.3
Python | 3.8.10
Database | MariaDB 10.3.34-MariaDB-0ubuntu0.20.04.1
RRDTool | 1.7.2
SNMP | 5.8
[OK] Composer Version: 2.4.0
[OK]
[OK] MySQl and PHP time match
[WARN] PHP version 8.1 is the minimum supported version as of September, 2022. We recommend you update PHP to a supported version (8.1 suggested) to continue to receive updates. If you do not update PHP, LibreNMS will continue to function but stop receiving bug fixes and updates.
Modified Files:
includes/definitions/iosxr.yaml
[FAIL] We have found some files that are owned by a different user than 'librenms', this will stop you updating automatically and / or rrd files being updated causing graphs to fail.
Files:
/opt/librenms/rrd/cfr4.wdc1/sensor-dbm-cisco-entity-sensor-2257180.rrd
/opt/librenms/rrd/cfr4.wdc1/sensor-dbm-cisco-entity-sensor-2269469.rrd
/opt/librenms/rrd/cfr4.wdc1/sensor-dbm-cisco-entity-sensor-2269467.rrd
/opt/librenms/rrd/cfr4.wdc1/sensor-dbm-cisco-entity-sensor-2248976.rrd
/opt/librenms/rrd/cfr4.wdc1/sensor-current-cisco-entity-sensor-2265340.rrd
/opt/librenms/rrd/cfr4.wdc1/sensor-dbm-cisco-entity-sensor-2265371.rrd
/opt/librenms/rrd/cfr4.wdc1/sensor-dbm-cisco-entity-sensor-2269455.rrd
/opt/librenms/rrd/cfr4.wdc1/sensor-dbm-cisco-entity-sensor-2253073.rrd
/opt/librenms/rrd/cfr4.wdc1/sensor-current-cisco-entity-sensor-2253053.rrd
/opt/librenms/rrd/cfr4.wdc1/sensor-dbm-cisco-entity-sensor-2265360.rrd
/opt/librenms/rrd/cfr4.wdc1/sensor-current-cisco-entity-sensor-2248956.rrd
/opt/librenms/rrd/cfr4.wdc1/sensor-current-cisco-entity-sensor-2269435.rrd
/opt/librenms/rrd/cfr4.wdc1/sensor-dbm-cisco-entity-sensor-2261277.rrd
/opt/librenms/rrd/cfr4.wdc1/sensor-dbm-cisco-entity-sensor-2253072.rrd
/opt/librenms/rrd/cfr4.wdc1/sensor-dbm-cisco-entity-sensor-2269454.rrd
and 59 more...
