Unable to remove device
On the latest release.
Trying to delete a device and getting a ‘Whoops’ error, looked in the logs and couldn’t see anything useful.
Attempted to delete via CLI using delhosts.php and get the following errors
In Connection.php line 671:
SQLSTATE[42S02]: Base table or view not found: 1146 Table ‘librenms.availability’ doesn’t exist (SQL: delete from availabi lity where device_id = 28)
In PDOConnection.php line 66:
In PDOConnection.php line 64:
Help is always appreciated.
./validate.php your install. It will tell you more or less the solution.
FYI: It looks like you updated the code but not the sql schema, so its trying to delete from tables that doesnt exists.
