Hi everybody !
Several weeks ago, i’ve setup Slack alerts. Then It worked.
Today i’ve seen no alerts since few days. I’ll want to test alert, but I’ve got an error “Test to slack failed - general error”.
I’ve tried to remote/add other alerts and type of alerts, same problem. I cannot remove this alert too.
On commande, i’ve got this
root@Librenms:/opt/librenms# /opt/librenms/scripts/test-alert.php -r 4 -d -h XXX
SQL[select * from `devices` where `hostname` = ? limit 1 ["XXX"] 0.29ms]
SQL[SELECT alerts.id, alerts.alerted, alerts.device_id, alerts.rule_id, alerts.state, alerts.note, alerts.info FROM alerts WHERE alerts.device_id = 4 && alerts.rule_id = 4 [] 0.14ms]
No active alert found, please check that you have the correct id.
An with ./validate.php
root@Librenms:/opt/librenms# ./validate.php
LibreNMS | 1.64.1-182-g6cceeb43f
DB Schema | 2020_05_22_020303_alter_metric_column (168)
PHP | 7.3.14-1~deb10u1
Python | 3.7.3
MySQL | 10.3.22-MariaDB-0+deb10u1
RRDTool | 1.7.1
SNMP | NET-SNMP 5.7.3
[OK] Composer Version: 1.10.7
Modified Files:
bootstrap/cache/.gitignore
logs/.gitignore
rrd/.gitignore
storage/app/.gitignore
storage/app/public/.gitignore
storage/debugbar/.gitignore
storage/logs/.gitignore
Is it normal ?
