Unbound application alerting
I am trying to create an alert for Unbound recursion time. I found an application alerting article that was very helpful, but I’ve been unable to get the Unbound alert to work.
This is what I have at the moment:
I’ve based this on:
I’ve left the >0 just to make it fire, there is no match when using the debug:
Rule name: Unbound recursion time increased
Alert rule: application_metrics.app_id = “unbound-recursiontime” AND (application_metrics.metric = “avg” AND application_metrics.value > 0)
Alert query: SELECT * FROM devices,applications,application_metrics WHERE (devices.device_id = ? AND devices.device_id = applications.device_id AND applications.app_id = application_metrics.app_id) AND application_metrics.app_id = “unbound-recursiontime” AND (application_metrics.metric = “avg” AND application_metrics.value > 0)
Rule match: no match
For reference, this is the article I found for application alerting:
Thank you
Best to look at the data in the table the alert is querying so you can see what you might need to base it on.
select * from application_metrics where device_id=X;
Thanks laf - that was a simple solution!
For anyone who finds this by search or otherwise, the Unbound alert for recursion time looks like this:
This is an example for >10ms
Simply tag it to the application hosts and/or group
Cheers
