Sorry, I can’t seem to fix this one.
librenms@nacho:~$ ./validate.php
| LibreNMS | 1.43-68-ge769d6b |
| DB Schema | 267 |
| PHP | 7.0.30-0ubuntu0.16.04.1 |
| MySQL | 10.0.36-MariaDB-0ubuntu0.16.04.1 |
| RRDTool | 1.6.0 |
| SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.7.2
Modified Files:
includes/services/check_icmp.inc.php
logs/.gitignore
snmptrap.php
librenms@nacho:~$ tail -n 1 logs/error_log
[Thu Sep 13 12:16:18.785203 2018] [:error] [pid 28293] [client 2620:31:40e0:6:87f:a68c:b870:1e74:51685] PHP Fatal error: Uncaught ReflectionException: Class view does not exist in /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php:729\nStack trace:\n#0 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(729): ReflectionClass->__construct(‘view’)\n#1 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(608): Illuminate\Container\Container->build(‘view’)\n#2 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(575): Illuminate\Container\Container->resolve(‘view’)\n#3 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(728): Illuminate\Container\Container->make(‘view’)\n#4 /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php(1172): Illuminate\Foundation\Application->make(‘view’)\n#5 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/RoutingServiceProvider.php(148): Illuminate\Container\Container->offsetGet(‘Illuminate\\Cont…’)\n#6 /opt/librenms/vendor/laravel/framework/sr in /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php on line 729
librenms@nacho:~$
Also recently did /opt/librenms/scripts/composer_wrapper.php install --no-dev
I did a chown without the rest and messed up the files that were 644, but www-data:www-data. Thanks, I’ll not make that mistake again.
