I have just tried to update Librenms, but during it i have this problem (after ./lnms migrate)
Migrating: 2019_07_09_150217_update_users_widgets_settings
In 2019_07_09_150217_update_users_widgets_settings.php line 19:
Undefined index: group
./validate.php says:
| LibreNMS | 1.68-86-g3456322 |
| DB Schema | 2019_07_03_132417_create_mpls_saps_table (141) |
| PHP | 7.2.17 |
| Python | 3.6.8 |
| MySQL | 5.5.60-MariaDB |
| RRDTool | 1.4.8 |
| SNMP | NET-SNMP 5.7.2 |
| OpenSSL |
[OK] Composer Version: 2.0.3
./lnms migrate
[WARN] PHP version 7.3 is the minimum supported version as of November, 2020. We recommend you update PHP to a supported version (7.4 suggested) to continue to receive updates. If you do not update PHP, LibreNMS will continue to function but stop receiving bug fixes and updates.
Modified Files:
bootstrap/cache/.gitignore
logs/.gitignore
rrd/.gitignore
storage/app/.gitignore
storage/app/public/.gitignore
storage/debugbar/.gitignore
storage/logs/.gitignore
I’m not sure what should I change in database
