When I can the config.php to include the sample line of code from https://docs.librenms.org/#Extensions/World-Map/
$config[‘map’][‘engine’] = “jquery-mapael”;
$config[‘mapael’][‘default_map’] = ‘mapael-maps/united_kingdom/united_kingdom.js’;
$config[‘mapael’][‘map_width’] = 400;
$config[‘mapael’][‘default_lat’] = ‘50.898482’;
$config[‘mapael’][‘default_lng’] = ‘-3.401402’;
$config[‘mapael’][‘default_zoom’] = 20;
I get this error in World Maps Widget on Dashboard “Mapael engine not supported here”
What am I doing wrong
LibreNMS | 1.38-7-gee2bb8e
DB Schema | 247
PHP | 7.0.28-0ubuntu0.16.04.1
MySQL | 10.0.34-MariaDB-0ubuntu0.16.04.1
RRDTool | 1.5.5
SNMP | NET-SNMP 5.7.3
[OK] Composer Version: 1.6.3
[FAIL] Database: incorrect column (notifications/datetime)
[FAIL] Database: incorrect column (users/created_at)
SQL Statements:
ALTER TABLE notifications
CHANGE datetime
datetime
timestamp NOT NULL DEFAULT ‘1970-01-02 00:00:00’ ;
ALTER TABLE users
CHANGE created_at
created_at
timestamp NOT NULL DEFAULT ‘1970-01-02 00:00:01’ ;
[FIX] Check your poll log and see: http://docs.librenms.org/Support/Performance/
Devices:
XXX.XXX.XXX.XXX
XXX.XXX.XXX.XXX
XXX.XXX.XXX.XXX
XXX.XXX.XXX.XXX
Modified Files:
poller-wrapper.py
