UniFi AP connection quality (CCQ) graph
Hello community. I have a problem, which, although not critical, deprives me of accessing useful information.
I have linked my UniFi controller with which I manage my Ubiquiti access points, via SNMP, with my LibreNMS.
In this way, from LibreNMS I carry out the entire NMS task, leaving the controller for the IPAM and DCIM tasks.
Until then, everything is fine. I see all the information without problems, except for the connection quality graph in the upper right part of each AP’s file.
What do you think? Could it be that I am not receiving the CCQ values? Will the OID need to be modified?
LibreNMS 23.11.0-29-g624eb5aa0 (2023-12-13T19:29:53-03:00)
DB Schema 2023_11_21_172239_increase_vminfo.vmwvmguestos_column_length (274)
PHP 8.1.2-1ubuntu2.14
Python 3.10.12
Database MariaDB 10.6.12-MariaDB-0ubuntu0.22.04.1
SNMP 5.9.1
I attach a screenshot.
graphCCQ
Try that
For now, what I got…
Debug:
graph
Runtime 0.567s
Show RRD command:
RRDTool Command
rrdtool graph /tmp/7wPeuTbZPQRt623y --start 1702917886 --end 1703004000 --width 1712 --height 483 --imgformat=SVG --font LEGEND:8:DejaVuSansMono --font AXIS:7:DejaVuSansMono --font-render-mode normal -c FONT\#000000 -c BACK\#EEEEEE00 -c SHADEA\#EEEEEE00 -c SHADEB\#EEEEEE00 -c CANVAS\#FFFFFF00 -c GRID\#a5a5a5 -c MGRID\#FF9999 -c FRAME\#5e5e5e -c ARROW\#5e5e5e -l 0 -u 100 --slope-mode  COMMENT:'CCQ                                Cur      Min      Max\\n'
Run that rrd command on your LibreNMS server and see what the output is.
The CCQ value is not sent by SNMP :roll_eyes:, but is calculated at source to be displayed in a proprietary web interface.
Maybe there is the problem with the graphics.
I will try to do reverse engineering to obtain it, and perhaps through extended SNMP, generate an OID that will send it to LibreNMS. :grimacing:
From there, I’ll load it as a custom OID, for sure.
Thank you so much.
Regards
Hi !
Unfortunately some newer unifi software does not support this OID.
The older versions is working well but the newer is not.
Regards
Please let me some examples:
CCQ is supported
Ubiquiti UniFi 4.0.10.9653
CCQ is not supported
Ubiquiti UniFi 4.0.42.10433
Ubiquiti UniFi 4.3.28.11361
Ubiquiti UniFi 5.43.56.12784
If you have valid support you should open a ticket at Ubiquiti.
Regards,
