Unifi Cloud Gateway Ultra OS Discovery / Detection
LibreNMS 26.1.1 (2026-01-23T17:51:17+00:00)
DB Schema 2025_12_05_205509_devices_add_mtu_status (362)
PHP 8.3.29
Python 3.12.12
Database MariaDB 12.1.2-MariaDB-ubu2404
RRDTool 1.9.0
SNMP 5.9.4
I have a Unifi Cloud Gateway Ultra, and a small number of Unifi Wireless Access Points connected and managed by the Unifi Cloud Gateway Ultra.
I can add each of the Access Points into LibreNMS and it correctly detects them as Ubiquiti devices, and displays the correct icon/logo
The actual Cloud Gateway Ultra (the router) only detects as Linux though, and not a Ubiquiti device.
Is there anything I can do/amend in LibreNMS to allow it to detect the Unifi Cloud Gateway Ultra os correctly?
The OS Detection yaml files (if im understanding correctly) seem to focus only on Unifi wireless devices, and not the routers/firewalls
An snmp discovery of a Wireless Access Point which detects the os correctly - ap-ac-lite-discovery - Pastebin.com
An snmp discovery of the Cloud Gateway Ultra with incorrect OS detection - Cloud-gateway-ultra - Pastebin.com
