Unifi Switch 24 POE detected as Linux
Hi!
Thank you for a fantastic product. I ran into some issues when adding my Ubiquiti UniFi Switch 24 POE Switch. It’s detected as linux but my Unifi AP works fine.
Steps to reproduce an issue
Add a Ubiquiti UniFi Switch 24 POE Switch to LibreNMS.
./validate.php
LibreNMS  | 1.66
DB Schema | 2020_08_28_212054_drop_uptime_column_outages (173)
PHP       | 7.3.21
Python    | 3.8.5
MySQL     | 10.4.14-MariaDB-1:10.4.14+maria~focal
SNMP      | NET-SNMP 5.8
[OK]    Installed from the official Docker image; no Composer required
[WARN]  IPv6 is disabled on your server, you will not be able to add IPv6 devices.
[WARN]  Updates are managed through the official Docker image
Discovery:
https://p.libren.ms/view/9e1ada8a
Poller:
https://p.libren.ms/view/0c76f55d
Any ideas would be super welcome!
Ps. Wow, you really made it easy to report issues!
Im almost sure both pastes have missing info. I see the snmp requests but not the replies.
Can you check all info is in the paste?
Thank you for your reply and sorry for my late one!
I ran it without piping to the shell script and here’s the output:
https://p.libren.ms/view/13d08311
https://p.libren.ms/view/6b37f78a
Kind regards,
Patrik
Found something here:
https://community.ui.com/questions/SNMP-support-for-USW-24-POE-GEN2-appears-to-be-incomplete/eac793b1-fbe9-4fb6-8013-058cbc44e896
Seems like this is a common issue. I’ve created a ticket with Ubiquiti.
/Patrik
Updating the firmware to the latest GA release made Libre detect the switch as a Ubiquiti device but the port OIDs is still unavailable when walking the device. Got this answer from Ubiquitis third line.
Hi Patrik,
Hope you are doing well. My name is Ben and I am with the UI Tier 3 Support Team. Thank you for getting in touch with UI Support.
We have received reports that the stats are available in the v5.x beta firmware:
https://community.ui.com/questions/SNMP-interface-metrics-unavailable-on-USW-16-POE/b628cb40-47b5-4790-8a18-cc74720a5099#answer/773d28b8-5e94-4733-b77b-2efc492ee634
I recommend to wait until the Beta firmware is officially released and update your device afterwards. Unfortunately, I do not have an ETA available at the moment.
Hope that helps!
You know you’ve bought a professional product when you have to use a beta version to get SNMP monitoring. :slight_smile:
