Hello dear LibreNMS Community,
I am working on Juniper RPM support the same way Cisco SLA is already working.
It is working and I will detail my changes in the pull request.
I am working with an Ubuntu 20.04 VM. I forked the LibreNMS project and created a new branch.
I was about to create a Pull Request but before I need to be sure that Unit tests are not mandatory.
So the unit test stopped at 40 % with the command ./lnms dev:check
I did not find any tests for Cisco SLA modules as my feature is really similar. So I suppose the unit tests are not set for this.
Could you just confirm please?
I am not really familiar with Unit tests but I will be happy to learn!
Please find here the output of validate script :
LibreNMS | 21.4.0-23-g0d1448b76
DB Schema | Not Connected (0)
PHP | 7.4.3
Python | 3.8.5
MySQL | ?
RRDTool | 1.7.2
SNMP | NET-SNMP 5.8
[OK] Composer Version: 2.0.12
Thanks in advance for your help and have a great day!
Yours sincerely.
