Unknown Object Identifier (Sub-id not found: (top) Error in Procera / Active Logic Device
Good morning,
I’m using LibreNMS 25.1.0.and I am currently adding new OIDs (from the PACKETLOGIC-MIB) to a Procera device.
I put the OID in the includes/definitions/discovery/procera.yaml file but when I run the discovery (php discovery.php -d -v -m sensors -h XX), I got the following error:
Load disco module sensors
Caching data: os sensors SNMP[‘/usr/bin/snmpbulkwalk’ ‘-v2c’ ‘-c’ ‘XXXX’ ‘-OteQUsa’ ‘-Ih’ ‘-m’ ‘PACKETLOGIC-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/procera’ ‘udp:XXX.XXX.XXX.XXX:161’ ‘channelStatisticsRxBytes’]
Exitcode: 1
channelStatisticsRxBytes: Unknown Object Identifier (Sub-id not found: (top) → channelStatisticsRxBytes)
Note; I get results from the device when I query directly using the OID (instead of the name)
Can you please help with the troubleshooting?
Thank you.
BR
Bruno Sousa
channelStatisticsRxBytes doesn’t exist in the PACKETLOGIC-MIB. At least not the version included with LibreNMS
Thank you for the comment.
I didn’t realize that.
It seems the PACKETLOGIC-MIB LibreNMS has is not the most actual one.
What is the best way to import the new one? Just “copy+paste” to the dir and overwrite it?
Thank you.
BR
Bruno Sousa
Yup, just overwrite the MIB with a more recent version.
I updated the MIB and channelStatisticsRxBytes exist now in the PACKETLOGIC-MIB I have in LibreNMS.
The error persists though.
Note that when I query the device using the numeric OID instead of the name ( in this case the numeric OID is 1.3.6.1.4.1.15397.2.1.181.3) the device responds and gives a value for it.
Any suggestion for the troubleshooting?
Thank you.
BR
Bruno Sousa
You’ll need to post the debug output of discovery/polling.
Hi laf,
It was a problem with the cache.
Somehow it was not assuming the new MIB that I put in the system, but when I cleaned the cache, it worked.
Now it is working! Case closed!
Thank you.
BR
Bruno Sousa
