Unknown Poller Module mib
There is an active poller module called “mib” in my devices in addition to hr-mib and ucd-mib modules.
And I also get the error “Module mib does not exist, please remove it from your configuration” in the librenms logs.
It is difficult to turn off this module one by one on hundreds of devices.
I cannot find a module matching this name in the Poller Modules settings .
How can I delete this module from the system entirely?
Thank you
LibreNMS 24.11.0 (2024-11-20T17:58:54+03:00)
DB Schema 2024_11_07_110342_custommap_edge_add_text_align (307)
PHP 8.4.1
Python 3.10.12
Database MariaDB 10.6.18-MariaDB-0ubuntu0.22.04.1
SNMP 5.9.1
[OK] Composer Version: 2.8.3
We have no poller module called mib so you most likely have added this yourself at some point. Check config.php for something related to poller_modules
