Dear All,
First of all I am a noob/beginner to LibreNMS and basic Linux user.
Urgent help required. I was upgrading Librenms from 1.58 to 1.64.1 through ./daily.sh script. It showed that Python 2 support dropped, hence I updated the CentOS 7 box with Python 3. After updating Python 3, ./daily.sh script, however it look like it is taking too much time at “Updating SQL-Schema” and to my bad the server rebooted.
This crashed the whole LibreNMS, Not able to pull the page. It seems like something with the DB. I ran the ./validate.php and it shows the error [FAIL] Your database is out of date!
./lnms migrate
However, when I run ./lnms migrate it give me 3 error at the moment. The details are as below.
indent preformatted text by 4 spaces
[root@adl-sp-nmsus librenms]# ./daily.sh
Supported PHP and Python version, switched back to master branch. OK
Updating to latest release OK
Updating Composer packages OK
Updated from 1.58 to 1.64.1 OK
Updating SQL-Schema
bash-4.2$
bash-4.2$ ./validate.php
Component | Version |
LibreNMS | 1.64.1 |
DB Schema | 2020_04_19_010532_eventlog_sensor_reference_cleanup (164) |
PHP | 7.2.27 |
Python | 3.6.8 |
MySQL | 5.5.65-MariaDB |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.10.7
./lnms migrate
bash-4.2$ ./lnms migrate
Application In Production! *
yes
Migrating: 2020_04_06_001048_the_great_index_rename
In Connection.php line 669:
SQLSTATE[42000]: Syntax error or access violation: 1091 Can’t DROP ‘deleted’; check that column/key exists (SQL: ALTER TABLE access_points DROP INDEX deleted, ADD
INDEX access_points_deleted_index(deleted)
In PDOStatement.php line 129:
In PDOStatement.php line 127:
bash-4.2$
Please DB expert and LibreNMS expert help me. The NMS is monitoring some production systems.
Thanks in advance for your valuable inputs.
Bhaggu
