I had some struggle with backing up the config of Netgear GS108Tv3 switches (especially with the prompt regex and the “terminal length 0” command missing on those devices and so they always got stock at “–More–” asking for user interaction). This updated netgear.rb seems to work. Can somebody revise it and maybe push it to the Oxidized repository? I don’t have git myself.
class Netgear < Oxidized::Model
comment ‘!’
prompt /([a-zA-Z0-9\s+-()]+)((#\s?)|(\s>))/
expect /(\n\s*–More–\s*$)|(^\s*(q)uit$)/m do |data, re|
if data =~ /(\n\s*–More–\s*$)/
send ’ ’
elsif data =~ /(^\s*(q)uit$)/
send ‘q’
end
data.sub re, ‘’
end
cmd :secret do |cfg|
cfg.gsub!(/password (\S+)/, ‘password ’)
cfg.gsub!(/encrypted (\S+)/, ‘encrypted ’)
cfg.gsub!(/snmp community (\S+) (.*)$/, ‘snmp community \2’)
cfg.gsub!(/snmp-server community (\S+)$/, ‘snmp-server community ’)
cfg.gsub!(/snmp-server community (\S+) (\S+) (\S+)/, ‘snmp-server community \1 \2 ’)
cfg
end
cfg :telnet do
username /^(User:|Applying Interface configuration, please wait …)/
password /^Password:/i
end
cfg :telnet, :ssh do
post_login do
if vars(:enable) == true
cmd “enable”
elsif vars(:enable)
cmd “enable”, /[pP]assword:\s?$/
cmd vars(:enable)
end
cmd “terminal length 0” if !vars(:smartpro) || vars(:smartpro) == false
end
if vars(:smartpro) == true
pre_logout 'exit'
pre_logout 'exit'
else
pre_logout 'quit'
pre_logout 'n'
end
end
cmd :all do |cfg, cmdstring|
new_cfg = comment “COMMAND: #{cmdstring}\n”
new_cfg << cfg.each_line.to_a[1…-2].join
new_cfg.gsub! /(?<!exit\n)^$\n\n\n/m, ‘’ # remove triple-line-breaks from paging but NOT in the config blocks (exit preceded)
new_cfg
end
cmd ‘show version’ do |cfg|
cfg.gsub! /(Current Time.+ )./, ‘\1 ’
cfg.gsub! /(FASTPATH IPv6 Management)./m, “\1\n”
comment cfg
end
cmd ‘show bootvar’ do |cfg|
cfg.gsub!(/ \x80.*/n, ‘’)
comment cfg
end
cmd ‘show running-config’ do |cfg|
cfg.gsub! /(System Up Time)./, ‘\1 ’
cfg.gsub! /\e[.\e[.K/, ‘’
cfg.gsub! /\cH/, ‘’
cfg.gsub! /(Current SNTP Synchronized Time:)./, ‘\1 ’
cfg
end
end
