Updating. How does it work?
Hi I got email from our librenms server:
We just attempted to update your install but failed. The information below should help you fix this.
warning: unable to access ‘/root/.config/git/attributes’: Permission denied
warning: unable to access ‘/root/.config/git/ignore’: Permission denied
error: Your local changes to the following files would be overwritten by merge:
html/pages/services.inc.php
Please, commit your changes or stash them before you can merge.
Aborting
But I do not have any git hub installed on the server, and I do not have anything in
’/root/.config/'
What is it? Shoud I install git on the server?
Log in to your server and run ./validate.php in your LibreNMS directory. You will need to fix any errors.
Great! I did it and it works fine!
