Ok, monkey see monkey do so I’ve followed instructions but getting nothing coming up with UPS NUT
https://www.luzem.com/2015/01/25/install-ups-in-centos-7/
and
upsc defender1200@localhost
battery.charge: 100
battery.voltage: 27.40
battery.voltage.high: 26.00
battery.voltage.low: 20.80
battery.voltage.nominal: 24.0
device.type: ups
driver.name: blazer_usb
driver.parameter.pollinterval: 2
driver.parameter.port: auto
driver.version: 2.7.2
driver.version.internal: 0.11
input.current.nominal: 6.0
input.frequency: 50.0
input.frequency.nominal: 50
input.voltage: 233.6
input.voltage.fault: 233.6
input.voltage.nominal: 240
output.voltage: 233.6
ups.beeper.status: enabled
ups.delay.shutdown: 30
ups.delay.start: 180
ups.load: 9
ups.productid: 5161
ups.status: OL
ups.type: offline / line interactive
ups.vendorid: 0665
snmpwalk -v 2c -c myreadonlypassword MYHOST_IP NET-SNMP-EXTEND-MIB::nsExtendObjects
NET-SNMP-EXTEND-MIB::nsExtendNumEntries.0 = INTEGER: 1
NET-SNMP-EXTEND-MIB::nsExtendCommand.“ups-nut” = STRING: /etc/snmp/ups-nut.sh
NET-SNMP-EXTEND-MIB::nsExtendArgs.“ups-nut” = STRING:
NET-SNMP-EXTEND-MIB::nsExtendInput.“ups-nut” = STRING:
NET-SNMP-EXTEND-MIB::nsExtendCacheTime.“ups-nut” = INTEGER: 5
NET-SNMP-EXTEND-MIB::nsExtendExecType.“ups-nut” = INTEGER: exec(1)
NET-SNMP-EXTEND-MIB::nsExtendRunType.“ups-nut” = INTEGER: run-on-read(1)
NET-SNMP-EXTEND-MIB::nsExtendStorage.“ups-nut” = INTEGER: permanent(4)
NET-SNMP-EXTEND-MIB::nsExtendStatus.“ups-nut” = INTEGER: active(1)
NET-SNMP-EXTEND-MIB::nsExtendOutput1Line.“ups-nut” = STRING: 100
NET-SNMP-EXTEND-MIB::nsExtendOutputFull.“ups-nut” = STRING: 100
Unknown
Unknown
27.40
24
240
233.6
11
NET-SNMP-EXTEND-MIB::nsExtendOutNumLines.“ups-nut” = INTEGER: 8
NET-SNMP-EXTEND-MIB::nsExtendResult.“ups-nut” = INTEGER: 0
NET-SNMP-EXTEND-MIB::nsExtendOutLine.“ups-nut”.1 = STRING: 100
NET-SNMP-EXTEND-MIB::nsExtendOutLine.“ups-nut”.2 = STRING: Unknown
NET-SNMP-EXTEND-MIB::nsExtendOutLine.“ups-nut”.3 = STRING: Unknown
NET-SNMP-EXTEND-MIB::nsExtendOutLine.“ups-nut”.4 = STRING: 27.40
NET-SNMP-EXTEND-MIB::nsExtendOutLine.“ups-nut”.5 = STRING: 24
NET-SNMP-EXTEND-MIB::nsExtendOutLine.“ups-nut”.6 = STRING: 240
NET-SNMP-EXTEND-MIB::nsExtendOutLine.“ups-nut”.7 = STRING: 233.6
NET-SNMP-EXTEND-MIB::nsExtendOutLine.“ups-nut”.8 = STRING: 11
