j808
13 September 2017 23:46
#1
Hi, for some reason the UPS and PDU devices stop graphing output and input data on voltage, amp, battery life, remaining battery time, etc after the last update. We are currently using Tripplite and Eaton UPS and PDU devices. What exact modules need to be enabled as well? I have the default.
Tripplite UPS
Discovery: https://p.libren.ms/view/8501fdd4
Poller: https://p.libren.ms/view/7a3cdf6b
SNMPWalk: https://p.libren.ms/view/371fc16b
Tripplite PDU
Discovery: https://p.libren.ms/view/f774d3cf
Poller: https://p.libren.ms/view/16b81803
SNMPWalk: https://p.libren.ms/view/96ad2256
Component
Version
LibreNMS
1.31.03-38-g5e5684f
DB Schema
206
PHP
7.0.20
MySQL
5.5.52-MariaDB
RRDTool
1.4.8
SNMP
NET-SNMP 5.7.2
Sorry, there was briefly a bug. Run daily.sh and discovery again and it will resume.
librenms:master
← murrant:config-bug
opened 02:49AM - 14 Sep 17 UTC
Missed calls when the function definition changed.
and a comment typo fix
DO… NOT DELETE THIS TEXT
#### Please note
> Please read this information carefully. You can run `./scripts/pre-commit.php` to check your code before submitting.
- [x] Have you followed our [code guidelines?](http://docs.librenms.org/Developing/Code-Guidelines/)
#### Testers
This change is [<img src="https://reviewable.io/review_button.svg" height="34" align="absmiddle" alt="Reviewable"/>](https://reviewable.io/reviews/librenms/librenms/7339)
j808
14 September 2017 20:21
#3
Ok Thank You seems to be working. I’m not sure why it doesn’t report PDU health data. It’s the same OIDs from what Tripplite said.
Probably should create an issue if you think something should be graphed and isn’t.
