Use librenms only for ping / ICMP
Hi guys,
I found the librenms on the internet, seems like Observium :slight_smile:
I have a question, if you guys can help me I apreciate:
Is possible use librenms only for Ping / ICMP instead of SNMP?
If yes, how can I do that?
regards
EDIT: LibreNMS allows ICMP only devices now.
Summary
Not yet, but there have been some requests for that.
Currently you can use the icmp service check to monitor ping only devices, but it isn’t optimal.
http://docs.librenms.org/Extensions/Services/
Thanks for the answer :slight_smile:
Any solution to avoid status SNMP down in Devices table?
Not at present.
