Working with the new host dependency feature (yay it’s finally here!) - some of us don’t use DNS in our networks, so devices appear in the dependency UI with the hostname data (an IP address in this case). Is there a way to have the UI display the sysName field instead of the hostname field so it’s a bit easier to identify devices?
Hi
I would also like to see this.
+1 on this.
I already have the following configured in the config.php
Force IP to Sysname
$config[‘force_ip_to_sysname’] = true;
It does’nt seem to make a difference though.
This is kind of available now - if you go to the device edit page (https://nms/device/device=1/tab=edit/) and place your cursor in the “This device depends on:” field, you’ll get a list of all your other devices by IP with their sysName beside them.
could it not also apply to the following page http://librenms/device-dependencies/ page too?
Any idea is Sysname will be supported in the Device Dependencies page? I have Force Sysname on for the rest of LibreNMS and it works well!
Device Dependencies is the key place to have Sysname to make life easier.
Hi @Cameron_Warren
It makes complete sense.
We just need contributors to actually code it. It is probably only 1 or 2 lines. May be only a few letter I would say. But LibreNMS is a community based project, so either you can motivate somebody to do it, or you do it yourself
Hey @PipoCanaja - I personally dont have the coding skills to do this - anyone willing to take a look at this?
Plus one for this.
Ps no coding skills either.
Should be merged in a couple of days, if the patch is accepted by the community. Nobody is a developper here, we all have a job (network admin, sysadmin, etc etc) and learn dev everytime we have an issue …
Bye
Thank you - looks great and has updated on my instance!
Much appreciated
