1.23
(2017-01-01)
Features
- Add nagios check_procs support (#5214)
- Added support for sending email notifications to default_contact if updating fails (#5026)
- Enable override of $config values set in includes/definitions.inc.php (#5096)
- Add APC UPS battery replacement status #5088
Bugfixes
- APC PDU2 Voltage Discovery (#5276)
- Empty mac adds an entry to the arp table (#5270)
- Restrict inventory api calls to the device requested (#5267)
- Update any IP fields using inet6_ntop() #5207
- Fixed passing of data to load_all_os() function (#5235)
- Support columns filter in get_port_stats_by_port_hostname api call (#5230)
- Restore usage of -i -n in polling (#5228)
- Empty routing menu where only CEF is present (#5225)
- Added service params for check_smtp (#5223)
- Misc warning fixes in mib polling (#5222)
- Added service params for check_imap (#5213)
- Execute commands using the numeric conventions of the C locale. (#5192)
- Remove usage of -CI, it is not allowed for snmpbulkwalk #5164
- Update F5 fanspeed discovery (#5200)
- Fix state_indexes for state overview sensors (#5191)
- Better Cisco hardware formatting (#5184)
- Cisco hardware name detection (#5167)
- Changed sql query for state sensors on device overview page to ignore null sensor_id (#5180)
- daily.sh install path (#5152)
- Cleanup printing ifAlias (#4874)
- Fixed broken http-auth auth module #5053 (#5146)
- Fix get_port_stats_by_port_hostname() to only return non-deleted ports #5131
- Stop openbsd using snmpEngineTime (#5111)
- Update raspberrypi sensor discover to check for sensor data (#5114)
- Add check for differently named Cisco Power sensor (#5119)
- Ability to detect Cisco ASA version when polling a security context (#5098)
- Fixed setting userlevel for LDAP auth #5090
- Arp-table uses array_column() breaking discovery on php <=5.4 (#5099)
- Allow html but not script, head and html tags in notes widget #4898 (#5006)
Documentation
- Updated rrdcached docs to include Ubuntu 16.x (#5263)
- Updated Oxidized.md (#5224)
- Removed mailing list in various places + small improvements to docs (#5154)
- Added Remote monitoring using tinc VPN (#5122)
- Added documentation on securing rrdcached. (#5093)
- Adding how to configure HPE 3PAR to documentation (#5087)
- Fixed example timezones (#5083)
Refactoring
- Removed and moved more mibs (#5232)
- Move OS definitions into yaml files (#5189)
- Updated Ups nut support
- Mibs E-G (#5190)
- Moved / deleted mibs A-D (#5173)
- Updated location of mibs starting with S (#5142)
- Update some devices to disable poller/disco modules by default (#5010)
- More Cisco ASA Polling Performance Improvements (#5104)
- Moved mibs T-U (or removed) where possible (#5013)
Devices
- Lancom wireless devices (#5237)
- Added additional detection for Cisco WAP 321 #5172 (#5248)
- Added support for TPLink JetStream #5194 (#5249)
- Added HPE MSL support #5072 (#5239)
- Added support for DCN switches #5031 (#5238)
- Added support for Cisco APIC devices (#5236)
- Zyxel ZyWALL Improvement #5185
- Added CPU detection for Zyxel GS2200-24 (#5218)
- removed all references to ‘multimatics’ and instead added generex OS
- Added additional support for F5 BigIP LTM objects
- Added additional support for Synology dsm (#5145)
- Add OS Detection support for Alcatel-Lucent/Nokia ESS 7450 Ethernet service switch #5187
- Added Bluecoat ProxySG Support (#5165)
- Added support for Arris CMTS (#5143)
- Added os Discovery for Brocade NOS V4.X and below. (#5158)
- Added support for Mirth OS #2639
- Juniper SA support #4328
- Added support for Zyxel MES3528 (#5120)
- Add more Edge core switches
- Add support for Ubiquiti EdgePoint Switch models (#5079)
WebUI
- Standardised all rowCount parameters for tables (#5067)
Security
- Update PHPMailer to version 5.2.19 (#5253)
