V1.32 Release + Changelog (September 2017)
1.32
(2017-10-01)
Features
  • Added more rules to the collection of alert rules (#7363)
  • Allow ignore_mount, ignore_mount_string, ignore_mount_regex per OS (#7304)
  • Added script to generate config for new OS (#7161)
  • Added Syslog hook for ASA support (#7268)
Bugfixes
  • If session save path is β€œβ€, php will use /tmp (#7359)
  • rfc1628 runtime - allow os quirks (#7340)
  • Small error when checking ios for wireless rssi (#7300)
  • Use Netscaler vserver full names (#7279)
  • Slower hardware can hit the schema update response timeout (#7296)
  • Do not issue non-master warning if on the release update channel (#7297)
  • Fixed quotes breaking powerdns app data (#7111)
  • Updated graph_types table so graph_subtype has no default value (#7285)
  • Fixed IPv6 host renaming (#7275)
  • Fixed Comware Processor Discovery && Hardware Info (#7206)
  • Added Extreme OS mapping to β€˜gen_rancid’ (#7261)
  • Reverted previous active directory changes #7254 (#7257)
  • Fixed Avtech sensor discovery (#7244)
  • Corrected variable for timeout messages in unix-agent.inc.php (#7246)
  • Update notification for users with updates disabled (#7253)
  • Fixed the empty() vlan detection check (#7241)
  • Re-added changes for #6959 removed by accident in #7128 (#7240)
  • Issues with Geist Watchdog sensors
  • Issues with Geist Watchdog miss-named variable in sensor pre-caching internal humidity and temperature was discovered twice humidity was mis-spelled in yaml discovery temperature and current had incorrect divisor in yaml
Documentation
  • Added new faq Why would alert un-mute itself? (#7403)
  • Added performance suggestion for 1min polling documentation
  • Updated Distributed poller doc as rrdcached needs -R to work properly (#7393)
  • Updated docs to include installing xml php modules + updated validate (#7349)
  • Reorganize authentication documentation (#7329)
  • Update RRDCached.md to clarify version for client/server (#7320)
  • Elaborated on permission issues with dmidecode for snmp (#7288)
  • Update Distributed-Poller.md to remove distributed_poller_host
  • Added debug to services.md (#7238)
  • Fixed API-Docs Link in webui (#7242)
  • Updated Services.md include chmod +x (#7230)
Refactoring
  • Rewrite is_valid_port() (#7360)
  • rfc1628 sensor tidy up (#7341)
  • Added detection of vlan name changes (#7348)
  • Rewrite is_valid_port() (#7337)
  • Use the Config class includes/discovery (#7299)
  • Updated ldap auth to allow configurable uidnumber field (#7302)
  • Improve yaml state discovery (#7221)
  • Added IOS-XR Bundle-Ether shortened/corrected forms (#7283)
Devices
  • Added basic detection for hanwha techwin devices (#7397)
  • Added sensor detection for APC In Row RD devices (#7385)
  • Added better hardware and version identification for SAF (#7378)
  • Added basic os for EricssonLG ES switches (#7289)
  • Updated Engenius OS detection (#7365)
  • Added detection for DPS Telecom NetGuardian (#7326)
  • Added support for Alpha FXM UPS devices (#7324)
  • Added detection for IgniteNet FusionSwitch devices
  • Added support for A10 ACOS devices (#7327)
  • Added more detection for Cisco SB devices
  • Added support for routeros to pull UPS info
  • Added additional detection for Cisco small business switches (#7317)
  • Added sensor support for Himoinsa Gensets (#7315)
  • Added support for SmartOptics M-Series (#7314)
  • Added DHCP Leases Graph for Mikrotik (#7333)
  • Added support for Toshiba RemotEye4 devices (#7312)
  • Added additional Quanta detection (#7316)
  • Added additional detection for Calix devices (#7325)
  • Added detection for Himoinsa Gensets (#7295)
  • Added detection for ServerChecks (#7308)
  • Added support for Saf Integra Access points (#7292)
  • Added basic Open-E detection (#7301)
  • Updated Arista entity-physical support to use high/low values from device (#7156)
  • Added support for Mimosa A5 (#7287)
  • Updated state sensor code for Netonix
  • Added support for Radware / AlteonOS OS/Mem/Proc (#7220)
  • Added support for DragonWave Horizon (#7264)
WebUI
  • Updated alert rule collection to be table (#7371)
  • Show how long a device has been down if it is down (#7336)
  • Makes the .availability-label border-radius fit in with the border a bit better
  • Added device description to overview page (#7328)
  • Greatly reduces application memory leak for dashboard (#7215)
API
  • Added ability to supports CORS for API (#7357)
  • Added simple OSPF API route (#7298)
