1.58 is our 71st release since we started releasing monthly releases. LibreNMS is still in need of additional reviewers at this time there are over 70 pending changes, many of which need review or guidance to get merged. If you would like to help review PRs, let us know in Discord .
We thank each and every of the 32 different contributors to LibreNMS this month. Make sure you thank them for their time and effort ![]()
The new settings system has settled a bit. If you would like to help add settings to the webui, check the docs and this example PR.
Support for collecting routing tables (with default limit of 1000 routes) has been added thanks to PipoCanaja.
SourceDoctor has been making little improvements all over. Itβs really great when people step up and fix the annoying issues.
22 devices have new or updated support.
You can find our change log here.
As usual there are some great changes cooking for next month. You can checkout the Pull Requests on GitHub and give feedback on them to help them get merged.
As always, happy monitoring.
