V1.68 Release + Changelog (September 2020)
1.68
(2020-09-29)
A big thank you to the following 44 contributors this last month:
Feature
Device
Webui
Snmp Traps
Applications
Api
Billing
  • Fix billing showing estimated transfer based on total of 1 days if billing day is first (#10445) - CirnoT
Discovery
Polling
Rancid
Bug
Refactor
  • Allow index rename migration to recover partially completed previous run (#12084) - murrant
  • Rewrite smokeping script to be an lnms command (#11585) - TheMysteriousX
Documentation
Translation
Misc
  • New index in alert_log table (#12143) - Negatifff
  • IRC Add more logging and debug info (#12140) - Olen
  • Don’t set nick on each tick (#12139) - Olen
  • List external commands in help. Allow reload of external commands (#12137) - Olen
  • Increase the read-buffer as 64 bytes can be a little small (#12136) - Olen
  • Remove unused “irc_chan”. Renamed to “irc_alert_chan” (#12135) - Olen
  • Add some variables to the init of the class (#12134) - Olen
  • Cast device_id to int to prevent type error in deviceCache::get() (#12076) - Jellyfrog
  • Add attach sysName to Prometheus. (#12061) - jasoncheng7115
Dependencies
