Validate config page report wrong issue
Hello Guys,
Two of my librenms server report an issue in the validate config page which is :
We have found some files that are owned by a different user than librenms, this will stop you updating automatically and / or rrd files being updated causing graphs to fail.
Fix: chown -R librenms:librenms /opt/librenms
Files
/opt/librenms/.pki/nssdb
After looking to the directory mention the rights are correct all along :
[root@lclmphnms librenms]# ls -al | grep pki
drwxr----- 3 librenms librenms 18 13 mai 00:15 .pki
[root@lclmphnms .pki]# ls -al
total 8
drwxr-xr-x 31 librenms librenms 4096 13 mai 13:21 …
drwxr----- 2 librenms librenms 6 13 mai 00:15 nssdb
No issue so far with librenms functionality themself .
Any help would be appreciate :slight_smile:
Both of my servers report the same issues.
OS is Centos 7.5 and below is the validate script return :
-bash-4.2$ ./validate.php
LibreNMS 1.39-49-g7cb930e
DB Schema 249
PHP 7.0.29
MySQL 5.5.56-MariaDB
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
[OK] Composer Version: 1.6.5
Thx u :slight_smile:
That validate output looks ok. If you are still having an issue post the entire output from validate.php
Still having the issue :
Here is the screenshot of the validate config page.
Do u need something more?
Found that setting chmod 755 on .pki directory solve the issue but maybe this is still something to address?
That file isn’t from us so it’s not something we can ignore. Remove it unless you have a reason for it to be there.
That is a linux cert store directory, created when you did the useradd for librenms. It can be deleted.
