[librenms@librenms ~]$ ./validate.php
| LibreNMS | 24.12.0-17-gc471998ee (2025-01-01T19:07:29-05:00) |
| DB Schema | 2024_11_22_135845_alert_log_refactor_indexes (310) |
| PHP | 8.2.25 |
| Python | 3.9.21 |
| Database | MariaDB 10.5.22-MariaDB |
| RRDTool | 1.7.2 |
| SNMP | 5.9.1 |
[OK] Composer Version: 2.8.4
./lnms migrate
Attempt to fix this issue (y or n)?:y
In Connection.php line 829:
SQLSTATE[42S01]: Base table or view already exists: 1050 Table ‘abilities’ already exists (Connection: mysql, SQL: create table abilities (id bigint unsigned not null a
uto_increment primary key, name varchar(255) not null, title varchar(255) null, entity_id bigint unsigned null, entity_type varchar(255) null, only_owned tinyint(
- not null default ‘0’,
optionsjson null,scopeint null,created_attimestamp null,updated_attimestamp null) default character set utf8mb4 collate ‘utf8mb4_uni
code_ci’)
In Connection.php line 587:
