Hi!
I have installed and configured weathermap plugin with the help of below video tutorial.
Everything works fine but if I run the ./vaidate.php afterwards then I get the following error.
[OK] Composer Version: 1.10.13
[WARN] Your install is over 24 hours out of date, last update: Sat, 19 Sep 2020 23:24:53 +0000
Files:
/opt/librenms/html/plugins/Weathermap/configs/ne.conf
Setting the chown Fix breaks my weathermap.
What should I do?
