We have a LibeNMS server and 2 Docker pollers. All 3 poll around 2k of devices.
I ran the validate script recently and have these issue below, could someone advise on how I fix these?
LibreNMS | 22.9.0-3-g06c361c2b
DB Schema | 2022_09_03_091314_update_ports_adsl_table_with_defaults (246)
PHP | 7.4.3
Python | 3.8.10
Database | MariaDB 10.3.34-MariaDB-0ubuntu0.20.04.1
RRDTool | 1.7.2
SNMP | 5.8
[OK] Composer Version: 2.4.4
[OK]
[OK] MySQl and PHP time match
[WARN] PHP version 8.1 is the minimum supported version as of September, 2022. We recommend you update PHP to a supported version (8.1 suggested) to continue to receive updates. If you do not update PHP, LibreNMS will continue to function but stop receiving bug fixes and updates.
[FAIL] Missing PHP extension: memcached
Please install memcached
[OK] Redis is functional
[WARN] Your install is over 24 hours out of date, last update: Thu, 29 Sep 2022 04:32:10 +0000
You can switch back to master with git checkout master
Modified Files:
includes/definitions/rutos.yaml
poller-wrapper.py
rrd/.gitignore
I have run the daily.sh
./daily.sh
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
Caching Mac OUI data OK
If I run the validate.sh it says I haven’t run the daily.sh for 24 hours still which is odd.
Any advice would be great. I thought I had memcache installed, how do I check and install?
