Hi, I’m new to librenms, but I keep getting the same error over and over again
- The output of
./validate.php
Component | Version |
LibreNMS | 25.5.0 (2025-05-16T23:23:44+02:00) |
DB Schema | 2021_02_09_122930_migrate_to_utf8mb4 (338) |
PHP | 8.3.19 |
Python | 3.12.10 |
Database | MariaDB 10.5.29-MariaDB-ubu2004 |
RRDTool | 1.9.0 |
SNMP | 5.9.4 |
[FAIL] Poller is not running. No poller has run within the last 300 seconds.
[FAIL] No python wrapper pollers found
[FAIL] Scheduler is not running
sudo cp /opt/librenms/dist/librenms-scheduler.cron /etc/cron.d/
exit status 1
root@ubdi:~/librenms#
I also strangely get no data, no matter what I do, the services etc. are running.
Docker also runs without any problems
