Validation gives Failure to update MariaDB will eventually cause issues ; ./lnms migrate - Gives Error
Dear All,
./validate gives the error
[FAIL] MariaDB version 10.2.2 is the minimum supported version as of March, 2021. We recommend you update MariaDB to a supported version 10.5 suggested). Failure to update MariaDB will eventually cause issues.
./lnms migrate
and ./lnms migrate, gives the error
-bash-4.2$ ./lnms migrate
  • Application In Production!     *
yes
Migrating: 2020_12_14_091314_create_port_groups_table
In Connection.php line 678:
SQLSTATE[42S01]: Base table or view already exists: 1050 Table ‘port_groups’ already exists (SQL: create table port_groups (id int unsi
gned not null auto_increment primary key, name varchar(255) not null, desc varchar(255) null) default character set utf8mb4 collate ‘ut
f8mb4_unicode_ci’)
In Exception.php line 18:
In PDOStatement.php line 112:
On the GUI I am getting the below error
Please help
Take a look on this topic:
Thanks, managed to manually upgrade MariaDB. GUI errors are gone, but still validation is giving DB out of date.
I had the same and after following another thread I dropped the port_groups table but now i get
SQLSTATE[42000]: Syntax error or access violation: 1071 Specified key was too long; max key length is 767 bytes (SQL: alter table port_groups add unique port_groups_name_unique(name))
Does nayone have a clue for me otherwise I shall make another thread.
I followed fit4130 advice from thread https://community.librenms.org/t/error-port-device/15386/17
Execute ./lnms migrate --pretend
after dropping the port_groups table again.
@Stephanvw you should run validate.php, I’m guessing you have a too old mysql version
I am in the same boat.
MariaDB has been updated to 10.5.9
Procedure I did:
  • Update MariaDB
  • Delete the port_groups table, this table had no data and was generating an error when executing the command: ./lnms migrate
  • run the command: ./lnms migrate
can you write commands, i didmt manage to delete table, neither to update mariadb
On a Terminal type:
mariadb
in maridab type:
MariaDB> connect librenms (or whatever the name of your db is
in DB type:
MariaDB [librenms] > drop table port_groups; (note the semicolon!)
and you are done! Leave DB with exit
Hello Everyone!
Ok. Confession… I am a total Windows guy doing my best to manage a few Linux servers for a company. I have got the same error message as listed above, and I have no friggin idea how to get this figured out. Have gone thru the steps, but getting no where. Does anyone have a few extra cycles that can walk me thru how to do this…???
Tim.
